Pro Firmware V203 Features Update Info
I. The update features of Pro Firmware V203 are as below:
1. Supports connecting an H2N recorder to the USB port to record spatial sound. Please update H2N firmware to the latest version before use.
2. Corrected issue that prevented the Pro's onboard display from turning off during low-light chromatism calibration.
3. Fixes occasional problem of frame loss during sustained video recording.
4. Improves system stability.
II. Details about the function and use techniques.
1. You can now connect an external H2N recording device to the USB port to record spatial sound!
Add the function of recording panoramic sound can be realized by using USB external H2N recording device.
The recorded panoramic sound will be the same as the one recorded by Pro itself, both of which follow the Ambisonic standard, which can be stitched and exported by Stitcher, and uploaded to platforms (that support this standard) such as Facebook and Youtube. Now you can enjoy the panoramic sound effect!
How to use H2N to record panoramic sound:
(1) As shown in the picture, keep the H2N input interface face the same direction with Pro's screen. With the same orientation/direction, the panoramic sound recorded by H2N will be consistent with the panoramic picture of Pro in sound coming direction.
(2) Use the USB cable to connect H2N with the Pro, set up the USB panoramic sound recording mode of H2N, and then you can use Pro to take videos or go live as usual. Please ensure that the firmware of H2N has been updated to the latest version before use.
The 203 firmware version has fixed the problem of frame loss during sustained video recording and makes sure the every video segment is of the consistent frame rate. For the content recorded using old firmware version that have the frame loss problem, you can import it into the latest version of Stitcher, right-click on the video and choose to fix its frame rate. This can help correct and modify all the videos and make sure they are of the same frame rate and timestamp.
4. Improve system stability.
This post is deleted!
Log in to reply
Looks like your connection to Insta360 Pro Forum was lost, please wait while we try to reconnect.
